1991 Toyota Pickup 4 cyl.
Old 12-23-02, 04:36 AM
jcpike
Good Morning,
This morning I turned on the fan for the heater, it would only work on high, the low settings would not work.
Any suggestions
Cheers
John
Old 12-23-02, 06:40 AM
F
fordman30
toyota heater
Switch may be bad. Take it out of the dash and have it checked
Old 12-23-02, 08:56 AM
Joe_F
This is usually a wiped blower resistor when you have high and no lower speeds.
Call up any dealer and ask for the replacement part and the location. Shouldn't be that expensive and only a couple of screws hold it in.
Old 12-23-02, 12:57 PM
B
Baldguy
Blower Resister
On my 1988 Pickup the resister is located in the fan housing under the passenger side of the dash. You'll have to get yourself in there upside down to unplug the harness and remove the one screw holding it in.
The part at the dealer was under 10 bucks as I remember. Easy to do job.
