2002 Tundra Check Engine Light P0155
Marshall Buttrey's Avatar
12-23-02, 06:17 AM   #1
Marshall Buttrey
Not sure what I am in to with the above message. Basically it means there is a fault in the Oxygen Heater Sensor.
I went to the Chilton manual at cyberparts.com and found 3 possible causes: lean fuel mixture, rich fuel mixture, or an open circuit. I need to connet a scan tool and measure the voltage to pinpoint the problem.
What is a "scan tool", and are there alternatives ways to isolate the fault?
I have noticed no difference in the way the pickup runs, except there may be a slight reduction in fuel economy, which might point to rich fuel mixture.
Thanks in advance for any (all) help.
Marshall Buttrey
fordman30's Avatar
12-23-02, 06:38 AM   #2
fordman30
toyota
Shouldnt it be still under warranty?
Joe_F's Avatar
12-23-02, 08:59 AM   #3
Joe_F
A scan tool is a device used in automotive diagnostics and costs hundreds or thousands of dollars for a good one .
You cannot read and interpret codes on OBDII vehicles like this without one (Or at minimum a code reader).
As Fordman mentioned, this is a 2002 vehicle---covered under warranty. Dealer's problem, not yours. Return it to them for free repair.
