1993 Sable piece of junk
Old 12-23-02, 04:50 PM
P
pweber
The third time I've been on here about the piece of crap. Have a slow antifreeze leak I'm trying to find. I jack the car up and find a small drip on the underside but can't find where it's coming from. Then try to start the car and it won't start. The exact same thing happened before and then it started. It's my daughters car and it's had an intermittant starting problem. It turns over but there is no spark coming out of the coil. I don't have a schematic. I've tried the website you guys have on your site but after I enter the model it won't let me go any further. Any help would be appreciated.
Old 12-23-02, 04:53 PM
Joe_F
Have you looked at my post "The Basics"?
Most likely cause of no spark on a Ford is the pickup or the module. The module, if distributor mounted is a known problem spot.
Yes, this is a bad heap not worth bus fare .
Old 12-24-02, 08:59 AM
the_tow_guy's Avatar
Received 45 Votes on 36 Posts
If that's a 3.8L, frequent leak source is timing cover gasket at the places where the water passages are located. Been there, done that on my brother's and it is a b****.
My sister's Windstar (3.8L) had some seepage from the same area but I staved off having to work on it by snugging up all the bolts.
Old 12-24-02, 09:00 AM
A little clarification; the timing cover-to-block gasket.
Old 12-25-02, 02:50 PM
Joe_F
It has to be a 3.8L---it has cooling problems .
I'm with TowGuy on the leak propensity and location.
