12-26-02, 04:20 PM
rtikql8
Vehicle info:
1992 Pontiac Grand Prix
3.1L V6
I had a very bad oil leak from the Intake manifold. Being the shade tree Jeep mechanic that I am I decided to tackle this myself. I've dismantled and removed the plemum, EFI, and everything else that was in the way.
In order to replace the valley pan gasket I had to remove 3 rocker arms and push rods on each side. (I thought this was a stupid design, nothing like the good old fashioned Jeep V8 that I'm used to.)
All gasket surfaces are clean and ready for reassembly, which leads me to my problem.
I have not been able to find the torque specification for this engine.
I need torque info on:
rocker arm nuts
intake bolts
plenum bolts
Does anyone have acess to this info or could you point me in the right direction?
Rob
3.1L V6
rocker arm nuts
intake bolts
plenum bolts
Rob
12-26-02, 04:22 PM
Joe_F
Ya should have a service manual when tackling a job like this....
Check autolibrary.org through my signature file below.
12-27-02, 01:46 PM
Rocker arm nuts = 18 Ft-lbs.
Intake manifold to cylinder head bolts/nuts = First take all to 15 then take all to 23 Ft-lbs.
Lifter guide bolts = 89 In-lbs.
Plenum to intake bolts = 16 Ft-lbs.
Throttle body to intake plenuim (just in case) =15 Ft-lbs.
But for under $20 you should really have a repair manual for this car. It'll help a lot for things like this in the future. I buy a manual for all of my cars, and am willing to give some information from it gratis.
Donations accepted (just kidding).
Good luck!
Good luck!
