Door Hinges
Old 12-27-02, 08:50 AM
T
tk1469
Question Door Hinges
I have a 95 Chev S10 Blazer - in good shape. The driver's door is "sagged" a little. I suspect that the door hinge or pins are worn. Does anybody out there know if just the pins can be replaced, the whole hinge, or the entire door???
Old 12-27-02, 09:27 AM
F
fordman30
i would replace the door hinges
Old 12-27-02, 01:03 PM
D
darrell McCoy
on that particular P/U the pins and bushings can be replaced.
Not expensive "If" you can DIY.
Old 12-27-02, 03:05 PM
Joe_F
Thumbs up
Correct. They are a little difficult to do on the earlier ones, I recall doing my neighbor's 1991 S10 Blazer.
Should be able to handle it with a helper or two.
