water pump
Old 12-28-02, 12:54 PM
stilbreathing
water pump
How do you check to see if your water pump is out? I have a 1992 Toyota Paseo. Any help I can get will be appriciated.
Thank you
Cheryl
Old 12-28-02, 04:28 PM
F
fordman30
fuel pump
Check to see if you can see a leak at the bottom of the pump.Also check and see if the water is circulating good.
Old 12-28-02, 04:31 PM
the_tow_guy's Avatar
Received 45 Votes on 36 Posts
Normally a water pump failure will show one of two things:
1. The pump leaks externally either through a weep hole or around the shaft.
2. The shaft has excessive play in it, has bad bearing noises, or seizes up entirely.
It is also possible to have one where the vanes inside are corroded badly which decreases the volume of coolant it is able to move; can't see this unless you remove the pump.
What problems are you having specifically?
Old 12-28-02, 05:22 PM
D
darrell McCoy
I have seen on very rare occassions the impeller was slipping on the shaft.
Old 12-28-02, 08:52 PM
Joe_F
Thumbs up
I'm with all these guys.
