stalling
Old 12-29-02, 02:04 AM
D
ddog65
Smile stalling
89"mecury,topaz,2.3,inline-4,4-door.
Vehicle starts and runs,but dies when the gear selector is moved into gear.Asif the ignition circut had been severed.
Old 12-29-02, 05:15 AM
Does it happen intermittently? Or all of the time. If it is all of the time, there is a possibility the torque converter clutch is not releasing. But Let's not jump the gun here. Is the Check Engine Light on? Does it run good? Is it Fuel injected or carburetted?
Old 12-29-02, 06:52 AM
Joe_F
Yamaha:
All 1989 Tempos are fuel injected.
Original poster:
Start with my "The Basics" link below.
Old 12-29-02, 07:25 AM
F
fordman30
to joe
joe could it be the idle conrol motor?thats what it sounds like to me ..maybe im wrong....What you think?
Old 12-29-02, 10:19 AM
Joe_F
Maybe, maybe not.
Not many details are furnished on the problem by the original poster, so we may never know .
Old 12-29-02, 11:52 AM
Yeah I know that, I didn't see he posted what year it was.
Old 12-29-02, 02:23 PM
R
roland1978
Lightbulb
The only way it could be lock up solenode is if it is a over drive trans in it. Never seen one with overdrive trans it.
Old 12-29-02, 02:31 PM
The locking converter clutch has nothing to do with overdrive other than the fact that if you have a trans with overdrive, you can acheive lock up in overdrive also. The converter clutch will lock in direct drive also. (3rd gear) Never the less it probably isn't the problem with this car since it's not a very common problem with them.
Old 12-29-02, 02:38 PM
R
roland1978
Ford didn't use lock converter on that year car or at all, except overdrive trans.
