94 Camry Idiot light question
Old 12-30-02, 01:28 PM
T
I have a 94 Camry (2.2, Auto). The last couple of days a "new" to me idiot light came on. It's orange in color, and it's on the bottom left side of the cluster. It looks like the picture of a car with the rear lights "on". My first guess was that one of the brake bulbs is not working. However, all seem to work ok. The light will be off when I start the car, and will come on either right when I press the brake pedal, or shortly after. It will sometimes flicker on or off, similar to a loose connection. But not always. I looked at Alldata, but I could not find a picture of the cluster. First I would like to know if that light is indeed a brake bulb idior light, and if so, what is the most likely source? Next I guess I'll go and check each bulb for a good connection....
Old 12-30-02, 01:30 PM
Joe_F
Burned out, improperly installed or wrong part # bulb installed, or a break in the wiring in the rear quarter area. Common on this era Camry as Larry "Toyotaman" will attest to.
Old 12-30-02, 02:05 PM
T
I've had this car for a bit over a year, and nothing was changed (bulb wise). I'll wait and see if Larry has another possible solution.....
Old 12-30-02, 02:16 PM
Joe_F
Check all the bulbs carefully in the meantime. If any are blackened or on the verge of burning out, replace them with the proper part #. Check the lamps closely, bet you'll find one of the burned out or blackened.
(Same thing just happened on my uncle's 97 Taurus this past Saturday. I changed both high mount stop lamp bulbs and the light went right out).
Old 12-30-02, 02:21 PM
T
Will do that tomorow morning... after I get the heater for the garage.
Old 12-30-02, 04:23 PM
the_tow_guy's Avatar
Received 40 Votes on 32 Posts
Definitely check the 3rd brake light. Mine went and I was going nuts trying to figure out why the warning light was on until I noticed the hi-mount burned out.
Old 12-30-02, 07:29 PM
check this
If my old memory serves me right that warning is for any light that is inop.Dont just check the brake lights but all running lights as well.
Old 12-31-02, 06:37 AM
Everyone has sent you in the right direction.
Just a hint....pay attention as when the warning lite lights up
Only turning on Tail lamps not hitting the brake= tail lamp problem
Applying the Brake=brake light problem
Larry
Old 01-01-03, 01:23 AM
T
I've found it...it was a dual-purpose bulb, both for the brake and the lights. The brake filament works fine, but the ligh filament only works when it wants to. A new bulb fixed the problem...thanks.
Old 01-01-03, 05:58 AM
good deal
Great you found the bulb and fixed it.That idiot light is a pretty good feature My 97 Camry had it.(to bad my ex got the car)My new Toyota does not have it but I check all bulbs on a regular basis anyway.
