Wiring Diagram
Old 12-31-02, 04:47 PM
G
Guitarman500
Angry Wiring Diagram
Hello, Im installing a Car Alarm For my Oldsmobile Delta 88 And I Was Wondering if The color of the Wires where the same through out the car, For example : The power Lock Wires are Green and Blue, does that mean those are the only green and blue Wires in the front of the car?
Old 01-02-03, 03:02 AM
D
Probably not.
If you're trying to get around trying to trace down all the wires, go to radio shack or harbor freight and buy a cheap ohm meter. Use that to check the wires for continuity.
Old 01-02-03, 07:08 AM
Joe_F
I agree with Dan. Get a meter and test light to check for power/continuity and also see if Autolibrary.org has a wiring diagram for your vehicle.
Failing that, order a 25 dollar yearly Alldata subscription or pick up a GM service manual which will have the wiring diagram.
Old 01-11-03, 05:53 PM
slappythegoat
www.the12volt.com is a great place to find the right wiring diagram. also has many usefull info on alarm and stero install.
