no heat 92 caprice
Old 12-31-02, 10:16 PM
W
wc2561
no heat 92 caprice
little heat, and gurgling sound coming from heater core. if the heater core is stopped up will that make it run hot in warmer weather and cold in cooler weather. any insight greatly apprecited..
Old 01-01-03, 06:03 AM
Jason R's Avatar
Are you sure you are full on coolant? The heater core in my ol' Mercury gurgles when the system is low on antifreeze. A stopped up heater core will not cause you any trouble with your engine running too hot or too cool. BUT, if you have something in your system that is causing clogs in your heater core, then that could be causing you trouble.
I bet if you fill your radiator up your trouble will go away.
But that won't address the problem that you likely have of a leak in the system somewhere (internally or externally).
Old 01-01-03, 07:35 AM
Joe_F
Do as Jason said, make sure the coolant is full and clean.
Warm up the car. Feel both heater hoses. Tell us if they are hot to the touch or not. If they are, it's a vent door problem inside the car.
