1989 seville
Old 01-04-03, 06:43 AM
B
bdwieser01
Unhappy 1989 seville
the car has a chip in the key and all the sudden one day the car anti theft system wont let the car start
Old 01-04-03, 06:51 AM
Joe_F
Clean the key with a pencil eraser and try it.
Failing that, look for broken wires under the column with the VATS anti theft system.
Failing that, bad VATS module or broken wires inside the column. A competent shop can solder in a proper value resistor to bypass the system and make it work like a normal car.
Old 01-04-03, 11:32 AM
O
otter_
cheap fix, but keep in mind that if you go the solder route, you'll have no anti-theft.
Old 01-04-03, 11:54 AM
Joe_F
Lol. True, Otter.
Not many people want a 1989 Seville though .
