1996 ford countour 4 cylinder
Old 01-05-03, 12:57 PM
H
hess
when replacing the starter do you have to remove the alternator so you can remove the wire from the selonoide?
Old 01-05-03, 03:56 PM
Joe_F
What does your service manual have to say?
If you don't have one (you should), check autolibrary.org below.
Old 01-06-03, 06:34 AM
F
Please explain exactly what the problem is.Make sure you remove the battery cable ends so that you don't get shocked or burnt.I can't think of why you'd ask this,being the alternator is nowhere near the starter.The only thing i can think is the large positive cable that runs on the back side of the engine so that's why i mentioned making sure you remove battery cables.
Old 01-06-03, 10:48 PM
REMOVAL & INSTALLATION
2.0L Engine
Disconnect the negative battery cable.
Remove air intake resonators.
Remove starter motor upper mounting bolts.
Raise and support the vehicle.
Remove the nuts on the starter terminals and remove the cables from the terminals.
Remove the two starter lower retaining bolts and remove the starter.
To install:
Place the starter into position and tighten the 2 lower retaining bolts to 15-20 ft. lbs (20-27 Nm).
Place the starter cables onto the terminals and tighten the retaining nuts to 80-124 inch lbs. (5-7 Nm).
Lower the vehicle.
Install and tighten the upper retaining bolt to 15-20 ft. lbs (20-27 Nm).
Install the air intake resonators.
Connect the negative battery cable.
