Keyless remote trunk release - cavalier
Old 01-06-03, 07:54 AM
H
2000 Cavalier (out of warranty)
The trunk release on my keyless remote is not working. At first it was an intermittent problem...now the trunk release has stopped working. When I press it I here the clicking noise from under the dash and see the headlights flash but the trunk does not open.
thanks
hanton
Old 01-06-03, 09:23 AM
Joe_F
May have a problem with the module that controls the release or the transmitter is bad.
Does another transmitter do the same thing?
Old 01-06-03, 09:25 AM
H
..we have 2 transmitters...both show the same problem
Old 01-06-03, 09:29 AM
Joe_F
Check autolibrary below to see if they have any information on the system.
Failing that, I would say a GM service manual would be the best reference.
Old 01-06-03, 11:06 AM
T
Open the trunk, find the release actuator, and connect a test light to it. Then press the button. If you have power, then the actuator is bad. If not, then either the wiring or control module is bad.
Old 01-06-03, 10:38 PM
Could be the actuator or the striker needs adjustment or lubed. The solenoid attached to the actuator may be weak. If you have a button in the car like in the glove box does it fail also, if it does than you know the problem is in the trunk.
