fuses
Old 01-08-03, 04:38 PM
corsica101
fuses
I am looking for the exact location of an irregular fuse (no. 323). The fuse is for a 1994 corsica. The fuse controls the turn signal lights. I know it's under the dash, but where? I have found the fuse that controls the flashers and it looks the same as this one. How much more farther is this one under the dash?
I will appreciate any help in this matter, thank you.:
Old 01-08-03, 06:39 PM
Joe_F
The actual problem would be a collosal start for me trying to help.
I assume you are looking for the turn signal flasher? Hit any parts store or GM dealer's parts counter and they'll find it for you/pull it up in the computer in a jiffy.
You probably found the hazard warning flasher. There are typically two flashers in a vehicle.
If the hazards work right and the turn signals do not, usually a bad flasher, yes.
Old 01-08-03, 07:43 PM
On your 1994 CHEVROLET CORSICA, the TURN SIGNAL FLASHER is:
FRONT SEATING AREA, DRIVER SIDE, UNDER DASH, DRIVER SIDE OF STEERING COLUMN, MOUNTED ABOVE CONVENIENCE CENTER
On your 1994 CHEVROLET CORSICA, the HAZARD FLASHER is:
FRONT SEATING AREA, DRIVER SIDE, UNDER DASH, ABOVE KICK PANEL, MOUNTED IN BOTTOM OF CONVENIENCE PANEL
