88 camry overheating
Old 01-09-03, 09:48 AM
dave1221
Question 88 camry overheating
88 toyota camry 2.0L(4cyl) 160Kmiles
it will run at normal temperature for 10 min driving around town, then it starts to heat up. also when i drive it on the highway(65mph) it runs hot(3/4). but when i slow down the gauge will drop at normal temp(1/4). i purchased a new radiator 2 yrs ago and filled it with anti-freeze, so i flushed it and fluid had a brownish color and i added fresh new water but that didnt seem to help... can someone help. thanks
Old 01-09-03, 09:59 AM
Joe_F
Brown in the cooling system means it's wiped out with rust.
It should be reversed flushed to remove all the junk. Go to any parts store and get a Prestone flush and fill kit to accomplish that.
The rest of the cooling system is likely trashed if you have rust in it like that.
You also likely have a stuck thermostat as well.
Old 01-12-03, 06:22 PM
dave1221
a stuck thermostat
thanks joe! the problem was a stuck thermostat...another successfull DIYer
Old 01-13-03, 10:22 AM
Joe_F
There you have it. But you must flush out the rust and scale or it will return and ruin things again .
Trackbacks are On
Pingbacks are On
Refbacks are On
