lock cylinder removal
Old 01-10-03, 09:18 PM
cynthiaZ2
The lock cylinder must be made of hardened steel. Carbon-tipped drill bits have no effect on it. Any other suggestions? The lock cylinder is in the dashboard, not the steering column.Can I take apart the dashboard and pry it out from behind?
Old 01-11-03, 03:29 AM
What is the year and vehicle? If you give good information, you will get helpful responses. We can't tell if you have a Willys Jeep or an old Corvette. Big difference in how you'd work on it!
Old 01-11-03, 05:02 AM
IT's the ignition lock cylinder? Most vehicles will not let you turn the ignition all the way off unless the transmission is in Park. Or Reverse M/T. check the linkage adjustment.
I'd suggest you get a service manual before trying to pry it out!
Old 01-11-03, 06:59 AM
Joe_F
How many posts on the same vehicle???? Please keep one post per vehicle or problem.
Bail out and have a locksmith handle it. Cheaper in the long run.
Get used to paying and paying dearly with an old European car like this. When they get old, they start to soak you like this .
Trackbacks are On
Pingbacks are On
Refbacks are On
