fuses
Old 01-15-03, 11:25 AM
E
ed stevens
fuses
Joe cool !!! I got your message the other day regarding the fuse problem . Thanks so much for the info ! I had checked and double checked all eqip on the #13 fuse line. The last thing I checked after looking at the wiring diagram(thanks to you) was the body control mod.. I unpluged it and tried the fuse, bingo, it didn't blow. I then checked wires coming and going from the body mod. and all looked good. I pluged wires back in and all works fine. I'v looked at all things again and all I can come up with is the body control mod. caused the short . Is this posible ? did the mod. reset and fix the problem ? Thank you for your time!!!
Old 01-15-03, 05:48 PM
Joe_F
Absolutely no idea what machine we are talking about.
Please use the reply button against the original post on the vehicle so we have vehicle specifics as well as continuit of the post.
Electronic modules can be sent out for testing by any parts store to their electronics supplier before buying a new one to confirm the original is indeed bad.
