motor indentification ?
Old 01-16-03, 08:57 AM
mrmojo's Avatar
could anyone tell me what this number means?its off a chevy motor would mainly like to know the year.its stamped on the back drivers side cjb25402.thanks
Old 01-16-03, 09:20 AM
Joe_F
You need to get the numbers from the flat pad on the RH side by where the alternator is mounted if it's a Chevy V8.
That is what tells you the Vin # it was installed in, and application details.
Just go to www.google.com when you find the numbers and type in "Chevy engine ID chart". You'll get more than you can shake a stick at.
Old 01-16-03, 09:46 AM
mrmojo's Avatar
it is a v6 out of supposedly an astro van I have been on google for about two hrs looking under chevrolet engine nmber codes.found out alot of stuff but not what i needed,gonna try what you said to look under thanks
Old 01-16-03, 04:40 PM
Joe_F
CJB might be a partial assembly suffix code, a GM dealer's parts counter could easily verify that in the microfiche/computer.
It is probably in the place I stated for this V6 as well.
Old 01-16-03, 05:09 PM
N
Nicholas
I dont know about newer motors but most GM V8's have the block #'s which Identifies the engine cast into the block right behind the drivers side cylinder head where the tranny meets the block. Maybe your V6 has a # in this position also?
Old 01-17-03, 01:20 AM
mrmojo's Avatar
i have found the number just wondered what it meant- its right in the back drivers side as stated there s not much info on v6s that i could find.thanxs for your time anyway
Old 01-17-03, 05:50 AM
Joe_F
Simply bring what you find to any GM dealer and they will look Group 0 of the Astro/Safari parts catalogs they have. In the front matter, they have what codes are what year and displacement.
