tranny troubles
Old 01-16-03, 03:25 PM
C
crosswind
tranny troubles
1994 Ford Explorer, 6 cylinder, automatic.one day no problems, next day tranny wont shift. goes from first to second fine, but not into third. RPM's get way high, almost red line, then i back off, and when the RPM's get down around 2000, the tranny shifts smoothly into third. Same story for third to forth, get my speed up, then coast until RPM's get down to about 200, and then the tranny shifts smoothly idnto fourth. Fluid level is perfect, color is clean, no leaks anywhere, no strange sounds at all.??????
Old 01-16-03, 03:43 PM
Check the governer.
Old 01-16-03, 04:28 PM
Joe_F
Sounds internally wiped. Mileage?
When did it see a tranny service last?
Old 01-17-03, 12:12 AM
cheese's Avatar
Received 30 Votes on 25 Posts
AOD tranny? If so, before throwing in the towel, check the governor. They are SOOO picky about the least speck of debris.
Like Joe mentioned, servicing it might help if it's been awhile. Has the radiator been removed lately? Sometimes garbage gets in the tranny via the cooler lines to the radiator.
