weird blinker problem
Old 01-18-03, 10:16 AM
T
tstokka
92 grand marquis ls, 4.6, auto.
problem: turn the blinker to the left everything is fine, turn to the right and it blinks real slow, about half that of the left. Bulbs all work.
Old 01-18-03, 02:08 PM
I would start by checking the bulbs themselves to make sure they are the correct ones and even replace them as thay are cheap enough. Check the sockets that they plug into for corrosion and also check your ground wires on that side.
Old 01-20-03, 05:44 AM
Joe_F
I agree with Stevo.
Old 01-20-03, 08:24 AM
T
tstokka
turned out to be a bulb, would work well for a while, hit a bump and then go slow again. I'm not sure which one, since i replaced all of them.
thanks for the help.
