95 Sunfire
Old 01-18-03, 07:28 PM
B
95 Sunfire
Hi guys, I have a 1995 Pontiac Sunfire and the wipers want go off
i have to take the fuse out and also my driverside window
want go up or down and i have pull it up with both hands one on each side of the window,it just slides down about 2 inches
all help is needed
thanks blackie
Old 01-19-03, 10:58 AM
Here's my 2 cents. Without doing a voltage check my first thought is that the park switch inside the wiper motor is not being opened properly or its shorted. As long as it stays closed voltage is supplied to the motor when the key is on or in Acc. That would mean replacing the motor. As for the window it sounds like you have a bad regulator or stripped power window motor gears(if equipped). You'll have to pull the door apart to do some more diagnostics.
Old 01-20-03, 05:08 AM
Joe_F
I agree with Stevo
