locked ingition
locked ingition
We have a 2000 Ford Focus 4dr sedan. The problem is that we cannot unlock the steeringwheel because the ingition switch willnot turn. We have tried to move the steringwheel while trying to turn the key. Any help would greatly appreciated.
Thanks again!!
Thanks again!!
Make sure the shifter is all the way into park. Try the shifter up and back a few times (put your foot on the brake when you do it).
Failing that, wiped lock cylinder or bad key. Dealer's problem. 2000 vehicle. If not, DO NOT attempt yourself as the air bag system may have be dismantled and without the proper know how, you could blow the bag off.
