geo knock
geo knock
hey hey ,k ,ive got a 96 geo-4 cyl-70,000 miles--the other day for the heck of it i put half a bottle of fuel treatment in-within 1 day a knock started i changed oil-plugs-oil filter-of course the knock didnt stop--people have told me its worn cam-knock sensor ect.ect--i took off valve cover and the knock is from down below...any thoughts-ideas of what it is and what i should do???
Hey if it is not your lifters knocking must be in the bottom end. That would be from wear in your main bearings but you would think it would last longer than 70k!?!?!? My tracker has 160k and she runs like a new one but i ran it out of gas and I can't figure out what is wrong with it if ya know i wish you could tell me but good luck on yours and have you ran it low on oil? O yeah my girlfriends dad said that fuel treatment hurts them more than it helps em I would run some good gas through it to clean the injectors.
Rent an oil pressure gauge from Autozone and measure the oil pressure. Match it to what's in autolibrary.org below.
If it passes the oil pressure check, the problem might be spark knock or something else. If it fails the check, you have internal engine problems.
Frankly, a Geo like this is a throwaway car and not worth the real effort involved to rebuild it. If the engine is toast, pitch the shoe for something more reliable.
