Transmission - no reverse
Old 01-24-03, 08:36 AM
callen
Question Transmission - no reverse
Last week when I started the car 1983 LeSabre (79000 actual miles) and I put it in reverse and a weird noise started - I immediately shut off the engine. I again started the car and no noise this time but I have no reverse! I only have first gear - won't shift into second. Hadn't had any previous problem shifting. Do I have a linkage problem or need a major overhaul. If so is a rebuilt tranny the only option?
Old 01-24-03, 09:00 AM
Joe_F
Check your fluid level and condition. When was the last time the transmission fluid and filter were serviced?
Sounds like internal failure of the trans...rebuild time.
