'94 Crown Vic Interceptor loose steering
Old 01-24-03, 09:43 AM
JoeNik...
Exclamation '94 Crown Vic Interceptor loose steering
My interceptor was recently checked for an alignment and was told all components were tight and wheels were in alignment. The steering wheel has way too much play and there is not much control at highway speeds (easy to over compensate).
Friends of mine (and the mechanic) familiar with crown vic's say they believe there is a way to tighten the steering box (dealer type tool job). A local dealer said the only way to fix it was to rebuild it ($400+) and said he was unfamiliar with "tightening".
Any suggestions?
Joe
Harrison, OH
Old 01-24-03, 01:06 PM
Joe_F
Probably the worm screw is what he means. No, I would not tighten it. Pitch the box for a rebuilt one. You can get them aftermarket at any parts store.
Old 01-24-03, 04:17 PM
Try taking a look at this link for adjustment sequence. This is not something for the non-experienced to work with and if not done correctly can cause your steering to bind up.
http://www.cybrrpartspro.com/Chilton...60CH08_29.HTML
If you do decide to replace the steering gear/box be sure and get the correct one as the police options usually have a different one that assures a "firm feel" of the road.
