92 accord front rotor removal
removal of front rotors-do I need 2 remove lower ball joint arm and upper arm? have pulley on hub but cannot back hub off axle spindle account of front wheel drive and various suspension components. I have calipiers off now and pushed out of the way. anyway know a short-cut or the simplist way to remove these hubs? thanks
dont touch the ball joints!!!!
the easiest way i have found to remove the front rotors of this type (fixed rotors ) is after removeing the axel nut from the end of shaft you attach a slide hammer type puller to wheel studs useing atleast 3 lug nuts and then use the slide weight to knock the rotor assembly off the bearing assembly. after the rotor assembly is off car there should be 4 to 5 bolts holding the rotor to the hub assembly when these are removed the rotor comes off the hub and to reinstall reverse the process except use the axel nut to pull the rotor/hub assembly back in place. you dont have to remove the ball joints or anything elsr except the axel nut.
