i am currently being driven nuts by a 92 chrsyler lebaron that on a left turn will go into first gear and will not shift until you shut the car off and restart then it will shift normally again any thoughts ? fluid level is fine and no codes are present
thanks
T:confused:Read More
Can anyone tell me how to remove a power steering pump pulley on a '92 astro van? I need to replace the pump, and it looks like you have to remove the pulley to get to the bolts that hold the pump on.Read More
