1996 Dodge Dakota NO HEAT
Old 01-27-03, 07:37 AM
J. Lacker
HELP! I have changed water pump and thermostat.
Water circulates, no leaks. Dash switch/fan works -
blowing "COLD" air only. What next?
Old 01-27-03, 09:34 AM
Joe_F
Warm up the vehicle. Feel both heater hoses going to the firewall.
If they are both hot, the problem is inside the vehicle with the vent door system. If they are not hot, still a cooling system issue. May have gotten a bad thermostat or you have air trapped in the cooling system.
Check autolibrary.org for any coolant bleed or flush procedures as well.
