66 mustang stalling at idle helllp
mustangerncal's Avatar
01-27-03, 05:20 PM   #1
mustangerncal
Thanks all for helping out. I drive a
1966 Ford Mustang-c4 trans-302 v8-600 cfm edelbrock performer carb and manifold. The problem I am having occurs after car is warmed up. While stopped and idling at a light or any period of time say 5 minutes... the motor just suddenly dies! It doesnt
stumble or exhibit any pre warning symptoms it just suddenly stalls. Then it wont start it just turns over but wont fire. Then it slowly starts to kick and it starts and runs fine. During normal driving it runs perfect. I reset timing and idle and air fuel ratio.
Any help you might have with this is greatly appreciated!
Thanks again all!
bejay's Avatar
01-27-03, 05:59 PM   #2
sounds like an ignition problem what type of ignition system is on it? it isnt still points and condensor is it.
01-29-03, 12:47 AM   #3
mustangerncal
stalling stang cont...
Thanks for the reply. No it wasnt the ignition. Currently Im running an MSD distributor and 6al. It turned out to be a bad pcv valve.
Thanks for the help it was appreciated.
Joe_F's Avatar
01-29-03, 03:28 AM   #4
Joe_F
Glad you got it fixed. In the future, please provide as much information such as modifications as possible. We cannot assume what you have in the machine---only you know .
