fuel injection kit
Old 01-28-03, 11:27 AM
shortcloud
fuel injection kit
I have a 1978 Triumph Spitfire and want to put a fuel injection kit on. Is this possible?
Old 01-28-03, 12:03 PM
it all depends if any aftermarket companys make a fuel injection kit to convert your car over to fuel injection which i doubt they do, most kits come with throttlebody, injector or injectors all sensors and wiring harness and computer, and the fuel supply system is modified with a higher pressure fuel pump and return lines back to tank, and do all this for what a car that will probably start easier and run about the same it does now and get about the same gas mileage it does now.
Old 01-29-03, 10:19 AM
Joe_F
BeJay is right. There are companies that probably do it. You might fare better swapping in a later fuel injected motor from a Triumph that had OEM Bosch injection.
Neither engine would be reliable as many of these older English cars are electrical and cooling system disasters.
