where is the coolant drain -lumina
Old 01-29-03, 11:42 AM
bryankknight
92 lunina ...cannot find the radiator drain..to do the thermostat
change...
Also how much should be drained....Ive been told to a level that
is below the thermostat.....well I cant actually see the level so what, a gallon or so?
any ideas?
Also can the drained coolant just be placed back in if it is clean?
Old 01-29-03, 04:19 PM
Joe_F
Now's a good time to change the coolant as you have to drain a gallon or so out to do the stat .
Check autolibrary.org for the other information you seek.
Old 01-30-03, 11:44 AM
bryankknight
autolibrary says that I cant go in cause my IP address is blocked.....
Old 01-30-03, 11:45 AM
bryankknight
nevermind...yor link works.....trying to just goto
autolibrary is blocked...
Old 01-30-03, 01:03 PM
Joe_F
Have to use the link as I have it in my signature file.
Old 01-30-03, 01:51 PM
The plugs on these newer cars dont look like the old petcocks used to. They are sometimes just a plastic pipe plug with a hex on it or maybe with a flat tab on it for you to grip with your fingers. Look at the bottom of the radiator tanks for this plug. Your tanks are located at the left and right side of the radiator and are part of it. When was the last time you changed the coolant...you you be wise to flush the entire system and install a new mixture 50/50 coolant and water.
Your drain may look something like this.
http://www.partsamerica.com/product_...B/5061109Z.jpg
Old 01-30-03, 01:56 PM
bryankknight
my coolant was flushed and filled like 3 months ago.
Old 01-30-03, 02:03 PM
Good, than drain in a clean pan and reuse. Drain to a level below the thermostat, you'll still hae some spillage when you remove the housing. Good luck-Stevo
