code for 2000 grand am se 2.4
Old 01-30-03, 12:01 PM
L
lakes
pulled a -PO171 system to lean (bank 1)-fuel pump issue? dirty fuel filter? any takers?
Old 01-30-03, 01:02 PM
Joe_F
Could be a number of things. What does your service manual have to say on this issue?
Old 01-30-03, 01:29 PM
Result for code: P0171
Manufacturer Description
SAE Standard=System Too Lean (Bank No. 1)
Probable Cause=Intake/Exhaust/Fuel System, Wiring, Injector, Mass Air Flow sensor, Engine Control Module
I would do the basics first, tune up and all filters, check fuel pressure. Reset codes and see what happens.
Old 01-30-03, 01:33 PM
L
lakes
I bought a haynes repair manual when I purchased the car-I take it I need the manufacturer supplied service manual to diagnose this problem?
Old 01-30-03, 04:53 PM
Joe_F
You sure should if you want to diagnose and fix it correctly. The Haynes manual is a table prop for any serious repair. The GM OEM manual is far superior.
Old 01-30-03, 07:07 PM
L
lakes
now that I have my new haynes manual propping open the broken garage door ! Where can I find a GM service manual without breaking the bank?
Old 01-31-03, 06:27 AM
Joe_F
