Radio LED not lit on my Bonneville
I have a 1997 Bonneville SE (40th anniversary edition) that is having a lighting problem. The LED light showing the radio station and the time display has quit working. It started going haywire in the last two weeks. At first it would work intermittently, sometimes on, sometimes off. Now it is not on at all. The other dashboard lights are not affected at all, just the one I mentioned so I don't think a fuse is involved. The radio has two independent sets of controls, one on dash and one on the steering wheel.
Does this sound like a dealer only fix it and does it sound expensive to troubleshoot? I can live with it the way it is but would prefer not to. Thanks.
You could also call the dealer/parts counter guy and find out who does their warranty work on radios. There might be a local shop that will work on it as all the dealer will probably do is remove the radio and send it away to the same repair shop. Many times a radio repair shop can remove, repair and reinstall while you drink their bad coffee in the lounge. Just a thought.
