1991 Pontiac 6000 3.1 not starting
Old 01-31-03, 11:18 AM
W
WhatQuestion
Help My 1991 Pontiac 6000 3.1 wagon doesn't want to start. I've tested the starter, it's getting power no prob. Car did start when we attached a starter button directly to the starter motor. The solnoid was corroded, so we replaced it. One connection just past the ignition was corroded, (sorry I don't know the names of these parts) so we cleaned it and greased it with the proper electrical grease stuff. It started okay for a day and a half but chugged occasionally and wouldn't idle properly. Then it would die completely. I put injection cleaner in the gas as well as gas line antifreeze/water remover this morning thinking it might solve the rough idle. It is now sitting in my sons' school parking lot. I looked under the hood to see if the wire connection we cleaned up might have been loose and found a small piston fully extended. It is attached to what my friend called a Nutral Safety Switch. Because the piston was clean and shiny, not normally exposed to the elements, I figured this is the porblem. However, I can't get the piston to retract to see if it is the problem. Anyone have any ideas?? Tks
Old 01-31-03, 01:28 PM
Joe_F
Start with the links and posts in my signature file below. Tell us what you find.
Old 01-31-03, 06:55 PM
Sounds like maybe 2 different problems? As it stands right now will the starter engage and turn over the motor when using the ignition switch?
http://www.cybrrpartspro.com/Chilton...08CH07_22.HTML
