high beam doesn't work !!!!!
Old 01-31-03, 02:27 PM
Hey everyone:
I own a 1996 Chevrolet Cavalier. Driving to work this morning, I was unable to use my high beam lights. When I tried to turn them on ( using the signal light arm ), my lights went out completely! Now I only have low beam, but my high beam indicator on the dash remains lit, whether I try the high beam or not. Any suggestions ????
Thanks in Advance........ ssshep
Old 01-31-03, 04:13 PM
Joe_F
Check both bulbs to be sure they work, but it sounds like a wasted dimmer switch. May require professional service as the steering column has to come apart and that means dealing with the airbag---don't risk it.
Old 01-31-03, 04:54 PM
Thanks for the quick reply Joe...... unfortunately, I've checked both bulbs and they test OK. Guess I'm off to the garage.
Thanks again.......... ssshep
Old 02-01-03, 04:39 AM
check this out
Check all the connectors on the steering coloum get under the dash and check them one might have came off.This happend to a buddy of mine with a Camaro.He found a connector had backed out pluged it back in and all was good.Hint use a good flashlight and move stuff around.
Old 02-12-03, 12:10 PM
Just to let you guys know........... it was a wiring issue, took it to a garage, just in case it was the dimmer switch, but was told the wires were corroded underneath the windshield washer container. Thanks again for the suggestions !!!!!!!!!!!!!!
ssshep
