air conditioner compressor
Old 02-01-03, 11:00 AM
T
tndeerhunter254
can the air conditioner compressor lock up and if it can,,,can it be disabled so that the drive belt will not burn up
Old 02-01-03, 01:25 PM
Joe_F
Yes it can lock up. Yes the belt will burn up. No it cannot feasibly be bypassed.
Old 02-01-03, 10:00 PM
If it locks up while is is engaged via the A/C controls on the dash then you can try unplugging the electrical connector for the A/C clutch on the compressor. If it locks up without the compressor clutch engaged than its time for a new compressor. do'nt even consider trying to reroute belts and taking your compressor completely off as this can be a real pain and you might not find the correct parts to do it properly and safely.
