Belts,86 Ford Tempo
Dave835's Avatar
02-05-03, 06:15 AM   #1
Dave835
Belts,86 Ford Tempo
I am changing the three belts on my 1986 Ford Tempo,Alternator,Power steering, Air,.I would like to know if i have to remove the Moter mount to get at lower belts.The ALT belt is right on top but the other two ,Serpentine belt and other V-Belt seem to be under moter mount.If any on has do this job i would appricate any heplfull input.Also if i do have to remove the mount do i have to put small jack under Moter to stop it from droping. 1986 ,Ford Tempo,2.3, Front wheel Drive,Auto Tran.
bejay's Avatar
02-05-03, 06:44 PM   #2
no you dont have to remove the motor mount but it might make it easier to get to the belts if you wanted to you would need to put a jack underneath the engine to support it, i think you may be forgetting the water pump belt that is easier to get to from working underneath the vehicle.
Joe_F's Avatar
02-06-03, 06:40 PM   #3
Joe_F
I agree with BeJay. Check autolibrary.org below as well.
