Honda Accord Clock
Old 02-08-03, 07:19 PM
jpsolo
Honda Accord Clock
I have a 1999 Honda Accord 4dr, 4cly,. The illumination for the OEM clock has gone out. All of the other panel lights seem to be working and the dimmer control under the speedometer is turned all the way up. I assume that the problem is a burned bulb but is it possible that there is a dedicated fuse for this application? If the problem is the bulb, how much of a job is it to change?
Old 02-09-03, 07:53 AM
Joe_F
Shouldn't be much of a problem if you can get the clock out---the owner's manual should have the bulb # if they use a bulb. Could be a wasted LED inside the clock.
Even though it might be slightly out of warranty, I would be at the Honda dealer's door asking for it to be fixed at no charge.
The 20+ year old analog clocks in my cars are still ticking .
