knock when accelerating after coasting
Old 02-09-03, 11:51 AM
F
frederick63
Question knock when accelerating after coasting
Hi.
My 1992 Plymouth Voyager (6cylinder, automatic, 110 K mi.) has a problem.
At times, when I accelerate, after coasting, I get less than full power from the transmission. Then, a knock or clunk from the lower driver's side inner drive axle area, and return of full power in the way of surge. From that point, no failure until after I coast again.
This problem occurrs at random, but seems to show up more often on cold days and is increasing in frequency.
Other info: Original transmission, drive axles replaced by Chrysler dealership 9 months ago, transmission fluid looks good, no visible damage to boots or axles, no correlation to turning or braking, rpms/engine steady and smooth--only happens when accelerating.
Any advice or suggestions as to diagnosis and remedy?
Thank you in advance.
Frederick
Old 02-09-03, 01:48 PM
Joe_F
Did it do it before the dealer did the repair? I'd bring it back to the dealer to have a look.
