94 GMC Safari stationary vibration
Old 02-11-03, 05:13 AM
sansabar
I have a 94 GMC Safari that has developed a bad vibration "overnight". Noticed more vibration than usual in the steering column after starting the van. With the brake still depressed the vibration got much worse in reverse, appeared to be about the same in drive and park, and maybe a little better in neutral. While driving the vibration is not as noticeable but it is still there.
Now when I say "bad" vibration, I mean it feels like one of those back massagers is rattling the enire van - especially in reverse. Any ideas where to look first? The van runs fine, has a 4.3 V6 w/ 125K+ miles and has been well maintained.
Old 02-11-03, 08:37 AM
F
Are you sure it's not an engine miss??? If it is check the wires,plugs etc.If it's not you might check engine and transmission mounts and maybe the harmonic balancer.
Old 02-11-03, 09:52 AM
Joe_F
I agree with Fordtech.
Old 02-14-03, 10:18 AM
sansabar
Problem solved. One marginal motor mount and the other just starting to rub. Thanks for the help!
Old 02-14-03, 05:01 PM
F
Your welcome!!!!!!!! Thank you for updating us too!!!!!!
