Hard Start - Synchronization Lost
Old 02-12-03, 09:15 AM
T
twebb455
1999 Plymouth Grand Voyager V-6 - Hard to Start
The Synchronization service code comes up as lost. The Cam and Crank check out okay. I've retested multiple times and had a few times that the synchronization was okay but mostly it shows it as lost.
Thanks for your help.
Old 02-12-03, 09:49 AM
Joe_F
The engine size would be a collosal help.
Check autolibrary.org below.
Old 02-17-03, 10:42 AM
T
twebb455
The engine is 3.3L
Old 02-17-03, 02:24 PM
Joe_F
What trouble codes are you getting and how do you know the sensors are good (what references are you using??)
Old 02-18-03, 08:14 AM
T
twebb455
I don't beleive there are any trouble codes. When they hooked up to the computer the cam and crank sensors returned okay.
I talked to a Chrysler service center. The service tech said it could be a number of problems. It could be as simple as disconnecting the battery cable (Which I've tried), short in wiring, oil on wire, cam and/or crank sensors may have problems. He said they usually start by replacing both sensors.
Old 02-18-03, 08:28 AM
Re: Hard Start - Synchronization Lost
How did someone arrive at this code loss? Has the computer been scanned for error codes and what are the code number/s?
Old 02-18-03, 08:53 AM
T
twebb455
Yes, a scanning device was hooked up by a repair shop and no error codes were found. The only thing out of the ordinary is the synchronization comes back as lost.
