high beam doesn't work !!!!!
Hey everyone:
I own a 1996 Chevrolet Cavalier. Driving to work this morning, I was unable to use my high beam lights. When I tried to turn them on ( using the signal light arm ), my lights went out completely! Now I only have low beam, but my high beam indicator on the dash remains lit, whether I try the high beam or not. Any suggestions ????
Thanks in Advance........ ssshep
check this out
Check all the connectors on the steering coloum get under the dash and check them one might have came off.This happend to a buddy of mine with a Camaro.He found a connector had backed out pluged it back in and all was good.Hint use a good flashlight and move stuff around.
Just to let you guys know........... it was a wiring issue, took it to a garage, just in case it was the dimmer switch, but was told the wires were corroded underneath the windshield washer container. Thanks again for the suggestions !!!!!!!!!!!!!!
ssshep
ssshep
