No Heat
No Heat
1992 Ford Crown Vic., 4.6L engine, 4 speed trans.
When the weather drops to 20 or below the car has no heat. The radiator has been flushed and it has a new thermostat. Not sure of what else the problem could be it was fine last year.
blend door system?? what is that?
I had a similar problem on my ford in cold weather, strangly it was because I was low on coolant.
How long ago was the flush, make sure you are topped off on your coolant levels.
The hoses are hot when the car is warm and the blend door seems to work also it goes from the lukewarm state I get to cold quick. The fluid was also flushed by Jiffy Lube 2 weeks ago. So you think I bought a bad thermostat?
I'd have to agree with Joe on this.If both heater hoses are hot to the touch then the problem has to be inside the interior of the car.If the core were plugged one of the hoses wouldn't get hot due to no circulation.Some of these had problems with the blend door actuator and also some even had blend doors that broke right at the top where the actuator connected to the door.You might have also had something fall into the heater housing that's blocking the door from fully closing.
My suggestion would be to remove the blower motor and you should be able to see the blend door and then check to see if anythings a miss.
