1995 pontic sunfire power window motor
hi guys thanks ,,got the wipers fixed,,
now i must start on my window it want go down by the button but slides down while driving
i went and got a new motor but what is the easest way to change the motors out and i no i;ll need a rivet tool but don;t know if i've ever seen one of those tools
all help is needed
thanks blackie
all help is needed
thanks blackie
suggest you get a repair manual for this job as it is tricky and you can end up in a WOS or worse, bunged up hand. As far as rivets, I just use bolts as the rivet tool you need is really a heavy duty tool. But again you may be able to rent the tool itself.
