Transmission
Old 02-19-03, 05:18 AM
AZbowhunter's Avatar
Red face Transmission
I have a 88 Nesson Maxima with a auto. trans.
The prob. is that when I shift from reverse or from park it will not go in to drive. The only way it will go is is if I shift to 2 range first then up to drive. After it is in drive the trans. works fine.
Also while parked doing the shifting it seems to shift hard with a slight clunk.
Thanks for any help.
Don
Old 02-19-03, 09:24 AM
Joe_F
Mileage? Last time the tranny fluid was changed? Sounds like internal failure.
Old 02-19-03, 10:03 AM
Question
Trany. has 190000.00
Can't remember when last changed but too long I think.
Don
Old 02-19-03, 03:31 PM
Joe_F
Borrowed time, likely internal failure. If the fluid is burned or dark, curtains .
Rebuild time in all likelihood.
Old 02-19-03, 07:44 PM
cheese's Avatar
Received 31 Votes on 26 Posts
Hey Joe...does it kinda sound like AZbowhunter may have a problem in the adjustment of his shift linkage. Usually I have found that when you have to shift to 2nd gear, then up to drive to get it in drive, its because the linkage has worn and/or come out of adjustment. I bet is goes into park just before the indicator shows that its supposed to as well.
Old 02-20-03, 03:37 AM
Joe_F
Could be Cheese---but zero detail is really given here and with that mileage, one can usually assume......................
LOL.
Old 02-20-03, 05:48 AM
Lightbulb Had heard
Cheese might be right! I have heard from my Son-in-law that a friend of his had the same prob. with the same type of auto. What this person did was have the linkage addjusted. That solved the problem.
I should look into this and hope that is all. It would be hard on my budget if I had to rebuild or get a new tranny.
Don
