1997 pontaic wont run
I have a 1997 4 cyl, quad pontaic grand am se 4 door. It starts and runs for few min then shuts down. I replaced the fuel filter and replaced the ignition control module, and im still having the same problem . Any suggestions ??
Tab
Tab
you need to do some testing and find out what the car is actually losing when it shut off, check fuel pressure, and check for spark for starters, when the car will not start, i know it isnt that easy to check for spark on the quad 4 but if you unbolt the cover flip it over while leaving it plugged in you can use a test light that is hooked to battery ground while you have someone crank it over.
this will give us a better idea of what the problem is it could be alot of things.
