escort starting problem
chumiser's Avatar
New Member
FL
02-25-03, 03:37 PM   #1
Hi there
My friends 95 1.9 liter wagon with air is cranking an unreasonable amount of time before starting.The longer it sits the longer the cranking that needs to take place. There is no sputter or combution prior to firing it just takes a long time. No other symptoms are evident
Thank you a lot
bejay's Avatar
02-25-03, 08:35 PM   #2
has it had any maintence such as tune up or fuel filter replaced lately, if it hasnt you should start there and if the problem still occurs you might want to run a fuel pressure test when starting to confirm that you have good fuel pressure as soon as the key is turned on.
Joe_F's Avatar
02-26-03, 09:43 AM   #3
Joe_F
I agree.
