engine flooding in 1996 Chrysler Lhs
The engine is hard to start due to a too rich mixture.The plugs and wires have been changed,as have the injectors.No fault codes are given on either the onboard engine test or the tester at the dealer.All sensors check good.All the grounds that I can find are tight.What else could be Wrong? It is a 3.5 liter engine.
