Transmission Problem
I have a 1991 Geo Storm 1.6L SOHC with an automatic transmission. It was recently in an accident where the front passenger side was hit in the tire. Aside from minor damage to the fender, the wheel rim was deformed and the lower support bar broke. So far I had the lower support bar and the wheel and everything else damaged there replaced. I just need it drivable again. But before I started the car up, I checked all the fluids and found that it had zero transmission fluid in it. I tried putting more in, and it all just leaked out. The tranny looks fine on the outside, no visible damage (I know, that doesn't mean a thing but I thought I'd say it anyway). Could this problem be something simple as a broken seal, or do I need to have the transmission rebuilt, or even replaced.
I can't believe I didn't think of looking at where the fluid is coming out from. I'll check when I get the chance. And if there is a crack in the case, is that going to be expensive to fix, or does that mean the tranny is gone and needs to be replaced?
Looks like I'll just get a used transmission from somewhere, that seems to be the safest bet. I'm going to keep the car, I've invested a lot of money into it already (sound system, reupholstery, etc.).
But what if there is no crack, at least one that I can find, is that situation usually better or worse?
Not sure I understand the question. If the tranny fluid is leaking out and you are finding puddles under the car of fluid, the cause has to be found and corrected. The tranny will puke in short order without fluid or by being low.
You might want to have a good tranny shop look at it for you (get a couple of opinions) to see what they say the problem is.
