GMC antifreeze leak?
PPakrs1's Avatar
03-05-03, 05:27 PM   #1
PPakrs1
1997 GMC 4x4 Xcab 1500 Sierra, vortex 350 w/67k miles.
I have to add antifreeze to the overflow tank every so often. I would guess approx. 6ounces every 500-750 miles or so.
I cannot visually see a leak anywhere, the oil is not foamy, heater works great and the engine parameters are normal.
My father-in-law told me that the intake manifold gasket is prone to leak on 350's, but I cannot see anything.
Any advise would be greatly appreciated!
Dean
Joe_F's Avatar
03-05-03, 05:37 PM   #2
Joe_F
He is correct.
djengr's Avatar
OK
03-06-03, 08:50 AM   #3
I am in process of changing intake manifold gasket due to leak on a 96 Tahoe 5.7L with 109K miles. Have you tried to pressurize your coolent system? It is very very hard to find, but with time and mirrors I could find mine after pressurizing the system with a little rental unit from the local shop.
PPakrs1's Avatar
03-26-03, 03:47 PM   #4
PPakrs1
As you can see, it took me awhile to address this problem (the truck pretty much sits in the garage all winter-its my baby!), but I rented a pressure tester from Autozone (I had to pay a $75 deposit, which was refunded to me after I returned the tester).
After pressurizing the radiator to 16psi, I found a very small seep coming from the intake manifold gasket at the front/passenger side.
Now its time to finally fix this. THANKS DJENGR FOR THE GREAT ADVISE!
Dean
redneck's Avatar
03-27-03, 08:47 AM   #5
redneck
I got a '98, same engine, same truck, 53k, I have had a very minor leak for some time, just never bothered me, and never really had to add fluid. It only leaves a small spot on drive way in real cold weather--other than that when it is warm or engine is hot--I never see anything! Course I was not aware of the intake manifold deal until now! Now it is going to bother me until I fix it!!--thanks!!
